For Weld assistant a promoted body needs to be created. Why?
Why we need to create promoted bodies or wave link before using weld assistant.
I given fillet weld by using assistant. It created the weld but when my parts are modified the weld does not update.
If I try to edit it gives error: UNEXPECTED TOPOLOGY ENCOUNTERED
And when I give the same weld on promote bodies it updates very well without error.
My question: why we need to create promote or link bodies for using weld assistant?
Please clarify.
Please clarify.
RE: For Weld assistant a promoted body needs to be created. Why?
Ben Loosli
Please tell me the reason in detail. or there is any another way to do this without promote or link bodies.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
no where in help or cast of NX 8.5 it is mentioned that you need to promote or link first
for using weld assistant.
And if that is the case then why it allows to give weld without promoting or linking bodies.
Wirh error on editing: UNEXPECTED TOPOLOGY ENCOUNTERED
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
