Cross-sectional properties using Patran Beam Library
How to get cross-sectional properties (moments of inertia, area, etc) if the cross-section consists of several separate parts? I usually get cross-section properties in Patran from Beam Library using Arbitrary Shape option. But in this case (several disjoint areas) it does not work. Thank you!
RE: Cross-sectional properties using Patran Beam Library
does anybody knows, how to solve the problem?
