Axial Load in Braced Frame Beam
I have multiple, non-symmetrical braced frames resisting wind modeled in Risa 3d. I applied the wind load to a single point attached to the rigid diaphragm at each level. Risa provides the axial load in the diagonal braces, but my question is if there is a way to trick Risa to quickly show the axial loads in the beams of the braced frames as well. (As I have it now I assume Risa attaches all of the horizontal beams to the diaphragm so they do not show any tension/compression) Hope this makes sense.
RE: Axial Load in Braced Frame Beam
It's not a perfect solution and it won't work for all models. But, it does work most of the time if you are careful.
