Adjustable treepan tool (O-ring face seals)
I need info on where to purchase an adjustable treepan tool.
I have seen one before, it was used on a Multi-spindle machine and was installed on the end tool slide.
It used an custom made 4 sided insert and the head was adjustable to allow for different dia's of o-ring face seals.
This will be used for forming the o-ring seats on the face
of a part.
Thanks Tim
RE: Adjustable treepan tool (O-ring face seals)
There are many different trepanning tools that can be purchased that use standard inserts.  You could mount one in almost any kind of adjustable holder that is suitable for endwork.  I'd page through the J&L catalog for starters. Hope that helps.
One manufacturer I am personally familar with is Manchester. They don't have a 4 sided insert, but their treepan tool is adjustable. You can see their catalog at www.manchestertools.com
