t' and tm in ASEM 16.34 Section 6.1.3
I would like to get my answer from you expertise.
In ASME 16.34 Section 6.1.3(c)
Valve Body Necks
The thickness of local valve body neck over distance of L shall be equal to t'.
The standard says: the t' value can be obtained from Table 3A.
However, Table 3A only gives Tm ( minimum valve thickness value) and I cannot find the t' data.
Can anyone tell me how to find t' value from the standard?
Thanks in advance.
Bao2
Valve Body Necks
Thanks in advance.
Bao2
