Industrial Lighting Standards
I'm working on installing an assembly operation in an existing building and I'm trying to determine how much workstation lighting would be sufficient. Does anyone have any standards/guidelines on how to determine what is the adequate amount of light?
Thanks - Jeff
Thanks - Jeff
RE: Industrial Lighting Standards
You can consult this volume and seach for you specific application.
The IES revised its illuminance standards for the 9th edition of their handbook. You might want to consult a copy of that. They also have published a Recommended Practice for Industrial Lighting that is considerably cheaper if you want to buy it.
Lightinguy
