Solenoid valve
Solenoid valve
Our supplier has offered a 240Vac soleniod valve when the voltage should have been 120V,1ph,60Hz. I have spoken directly with the valve supplier and they say they have a 110V,1ph,60Hz solenoid. Just to ask if this would work with the 120V? assuming it has appropriate tolerance.
RE: Solenoid valve
All I can suggest is 'assume nothing'.
Mike Halloran
Pembroke Pines, FL, USA
RE: Solenoid valve
Bill
"Why not the best?"
Jimmy Carter
RE: Solenoid valve
Liamc85, always double check the specs and get a datasheet. Look at the voltage ranges, both pull in and drop out, as well as current / power draw and verify that it is suitable. You will also want to verify the contact ratings against the type of load you will be running (e.g. DC, AC, or AC Motor (inductive)).
