Flue Gas Compression - Need Impurities
Hello everyone,
I am a new engineer and I have a question I find quite challenging. I am working on a project in which we need to compress flue gas into cylinders from one of our plants to a research facility approximately 300 miles away. We are conducting research on the scrubbing potential of a certain mixture and would like to simulate the flue gas' original composition as closely as possible. The composition is approximately as follows:
H2O: 4.5%
O2: 15.5%
CO2: 3%
N2: 77%
Trace amounts of NOx, SOx, CO, assorted HC
The flue exits the stack at around 450 F. If we were to chill it to 100 F and then compress it to 1500 PSI, would all of the impurities and CO2 drop out? For this project, I am looking to keep as many of the impurities as possible. I imagine I would have to compress it to a lower pressure to keep them from dropping out.
Dan
H2O: 4.5%
O2: 15.5%
CO2: 3%
N2: 77%
Dan
RE: Flue Gas Compression - Need Impurities
Why not just make your own sample of the stuff in the lab, why compress and ship it?
TOTAL VAPOR INCIP L1 LIQUID 2 TOTAL
ID COMPONENT NAME LBMOL/HR LBMOL/HR MOL FRA LBMOL/HR MOLE % KVALUE
2 METHANE 0.009999 0.009999 .1594E-06 .3854E-07 0.010423 655.429
47 OXYGEN 15.4984 15.4983 0.000201 .4868E-04 16.1551 804.236
48 CARBON MONOXIDE 0. 0. 0. 0. 0. 7.96209
49 CARBON DIOXIDE 2.99913 2.99889 0.000999 0.000241 3.12622 31.3723
46 NITROGEN 76.9919 76.9918 0.000750 0.000181 80.2546 1072.31
62 WATER 0.435196 0.193916 0.998051 0.241280 0.453638 0.002030
TOTAL 95.9346 95.6929 1.00000 0.241751 100.000
