NX8 Import CGM
NX8 Import CGM
NX8 Import CGM
I'm exporting CGMs (from the File -> Export -> CGM option, not the SDI dialog) using the color setting of Black on White. When I try to turn around and import the resulting CGM back into NX, all the lines are black and using our standard black background, I'm forced to edit all of the object colors to something other than black. While this is working as expected, I have a user sitting behind me who does the EXACT same thing and when he imports the SAME CGM file, his is all grey in color.
My question: why is mine black and his not (using the SAME NX defaults) upon import? Seems like there is a setting somewhere that's doing this - will check into Windows desktop settings because I know that while obscure, they sometimes will affect things in NX.
Any insight would be GREATLY appreciated.
Tim Flater
NX Designer
NX 8.0.3.4
Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
RE: NX8 Import CGM
Does your coworker have the 'wireframe contrast' option turned on in NX?
www.nxjournaling.com
RE: NX8 Import CGM
Yep, that was it. Just found it as you were posting.
Thanks cowski.
Tim Flater
NX Designer
NX 8.0.3.4
Win7 Pro x64 SP1
