Valve Supplier API license Suspended - How to Follow Up
Some assistance please,
One of our valve suppliers out of China have had their API license suspended and we have placed a large ball valve order through them. It appears that the API certification may have expired due to paperwork issues rather than quality concerns, however that is unproven. Either way, there may be issues regarding warranty and the acceptability of any valves that were manufactured while the API certificate was lapsed.
Any ideas how we stand here legally or from a warranty point of view should any of the valves from this order fail in the field ? Should we block these valves being put in service until the API license is recertified ?
Any other ideas from a technical point of view on how I should follow this up ?
Chasserman
RE: Valve Supplier API license Suspended - How to Follow Up
This company lost their certification either before or after your valve order was complete. I'll bet that the valves manufactured while the certification was lapsed are marked with the same stamps as the ones before and after the lapse. If loosing the certification truly was just a paperwork snafu then you don't have anything to worry about (beyond what you should be worrying about in any low-bid job). If they lost it for cause, that means that enough people complained loudly enough to force an enforcement action. If that is the case I would take all the valves from that manufacturer and sell them to a scrap metal dealer. Even with an enforceable warranty, you will spend more money blowing down your lines and in lost production during a shutdown than the low-bid savings could ever be worth. I always ask my clients to calculate the value of the gas they will have to blow down if a particular valve failed. Often, the answer is staggering--it is common for a single blowdown to cost more than 10,000 times the cost savings between low bidder and high bidder. But we keep treating valves as a commodity.
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
The plural of anecdote is not "data"
