Convert CATPart in multiple convex parts to be used in 3ds Max
I have just starting using 3ds Max to create some dynamic simulation using models built on CATIA.
As you may know, 3ds Max use only convex shapes in order to simulate dynamic bodies. Just to be clear, a box is a convex shape, while a tube is concave shape. :)
So I have a complex CATPart that basically I have to re-model using multiple convex shapes. And it's very long job when you have complex 3D models. So I would like some tips to simplidy the work.
Does someone know how to divide one CATPart into two, and then as a result you get 2 CATPart into one CATProduct?
I don't know if I am so clear, please let me know and I'll try to formulate it in a different way.
Thanks!
Thanks!
RE: Convert CATPart in multiple convex parts to be used in 3ds Max
Otherwise is a little complicated, I remember it was a macro which could convert a part with multiple bodies in a catproduct...anyway, this is the ideea, multiple bodies to be converted in simple parts and then in a product....
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
Thank you Fernando for your answer.
So if I understood well, for example, you have a CATPart with two cubes inside (simply made out of 2 pads). Is it possible to convert those 2 pads as separated CATParts and then the inital CATPart becomes a CATProduct?
Actually it is just a question of hierarchy in the tree. Moving everything one level up. If such a thing is possible, it would be an improvment for transfering models to 3Ds Max.
Thank you,
Br,
Romain
A macro (or built in tool with CATIA) that allows the functionality to go from CATPart bodies (or features) to CATProduct would be handy for exporting CATIA models to various 3rd party rendering packages like Bunkspeed SHOT too, in addition to programs like Maya and 3DS Max.
I know there is a tool in CATIA that allows you to generate a CATPart from a CATProduct. I think you need the ASD or PDG license to utilize it though. I'm surprised there's not something to do the opposite. If it's not already in CATIA then surely someone out there has already written a macro to do it...
Drew Mumaw
http://www.drewmumaw.com/
http://www.textsketcher.com/
The code below was posted long time ago on catiav5forum.de (which is not existing anymore). I remembered that I have it because I've done a modification to be used also under UNIX OS.
Have fun
CODE --> CATScript
' ============================================================== ' Purpose: A CATPart with multiple bodies inside can be transformed in a CATProduct ' Usage: 1 - You must have a CATPart as active document ' 2 - Run macro ' Author: gvi70000 (Disclaimer: You use this code at your own risk) ' =============================================================== Sub CATMain() Dim i, n As Integer Dim name, prt As String Dim BodyName() As String Dim partDocument1 As PartDocument On Error Resume Next Set partDocument1 = CATIA.ActiveDocument If Err.Description = "Type mismatch" Then MsgBox "You must have a CATPart as active document" Exit Sub End If name = partDocument1.FullName Dim part1 As part Set part1 = partDocument1.part Dim bodies1 As Bodies Set bodies1 = part1.Bodies Dim body1 As Body Dim sel As Selection Set sel = partDocument1.Selection Dim documents2 As Documents Dim partDocument2 As PartDocument Dim part2 As part Dim specsAndGeomWindow1 As SpecsAndGeomWindow n = bodies1.Count If n = 1 Then MsgBox "There is only one body in:" & Chr(13) & name & Chr(13) & "Part MUST have at least 2 Body's" & Chr(13) & "Macro will end now!!!", vbExclamation, "Warning" Exit Sub End If prt = Left(partDocument1.name, Len(partDocument1.name) - 8) For i = 1 To n ReDim Preserve BodyName(i) BodyName(i) = prt & "_" & bodies1.Item(i).name Set partDocument1 = CATIA.ActiveDocument sel.Clear sel.Add bodies1.Item(i) sel.Copy Set documents2 = CATIA.Documents Set partDocument2 = documents2.Add("Part") partDocument2.Product.PartNumber = BodyName(i) Set partDocument2 = CATIA.ActiveDocument Set specsAndGeomWindow1 = CATIA.ActiveWindow Set part2 = partDocument2.part sel.Add part2 sel.PasteSpecial ("CATPrtResult") part2.Update Set partDocument2 = CATIA.ActiveDocument partDocument2.SaveAs Left(name, Len(name) - Len(partDocument1.name)) & BodyName(i) & ".CATPart" specsAndGeomWindow1.Close partDocument2.Close Next 'i Dim documents1 As Documents Set documents1 = CATIA.Documents Dim productDocument1 As ProductDocument Set productDocument1 = documents1.Add("Product") productDocument1.Product.PartNumber = "Product_From_Part_" & Left(partDocument1.name, Len(partDocument1.name) - 8) Dim product1 As Product Set product1 = productDocument1.Product Dim products1 As Products Set products1 = product1.Products Dim arrayOfVariantOfBSTR1(0) Dim constraints1 As Constraints Set constraints1 = product1.Connections("CATIAConstraints") Dim reference1 As Reference Dim constraint1 As Constraint Dim ConString As String For i = 1 To n ConString = "" ConString = "Product_From_Part_" & prt & "/" & BodyName(i) & ".1/!" & "Product_From_Part_" & prt & "/" & BodyName(i) & ".1/" arrayOfVariantOfBSTR1(0) = Left(name, Len(name) - Len(partDocument1.name)) & BodyName(i) & ".CATPart" Set products1Variant = products1 StrConstrain = "Product_From_Part_" & Left(partDocument1.name, Len(partDocument1.name) - 8) & "/" & Left(partDocument1.name, Len(partDocument1.name) - 8) & "_PartBody.1/!" & "Product_From_Part_" & Left(partDocument1.name, Len(partDocument1.name) - 8) & "/" & Left(partDocument1.name, Len(partDocument1.name) - 8) & "_PartBody.1/" products1Variant.AddComponentsFromFiles arrayOfVariantOfBSTR1, "All" Set reference1 = product1.CreateReferenceFromName(ConString) Set constraint1 = constraints1.AddMonoEltCst(catCstTypeReference, reference1) Next 'i End SubRegards
Fernando
I've come across that user, gvi70000, before. Thanks for sharing. It's a shame that catiav5forum.de isn't running anymore - I liked that CATIA forum...
Drew Mumaw
We had a need to convert some old multi-body CATPart files into a CATProduct and we came across this thread with the script you provided. It worked great! Saved us a lot of time and headaches. Thanks for posting the code.
