Load Curve in LS_dyna
I need to implement the strain rate effect on a material model using load curve table. The example for material model 72r3 in ls-dyna manual has used 1/milliseconds for strain rate unit; And now I am confused shall I input strain rate in 1/ms regardless of time unit I am using in the model?
I'd appreciate any comment on this.
RE: Load Curve in LS_dyna
You have to use consistent units in load curves, so that. This case if you use seconds as your time unit, 1/s would be your strain rate units. There are a few cases where units are hard coded but almost always you just follow a consistent unit system.
