define surface?
define surface?
Hello everyone.
I build a 3D block. then i made partition for the block to define different properties. Hence the block is divided into several layers. For some reason i could not define a surface for one of the inner layers.
When i could Not select the surface of that inner layer. That is why i could not define the surface.
Any body can help me, how can i overcome that problem?
Chen
Chen
RE: define surface?
Are you new to this forum? If so, please read these FAQ:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
RE: define surface?
I follow your advice, but i still could not select the face to make surface.
So the problem is Abaqus does not allow me to select that face.
RE: define surface?
Do you know what is wrong?
RE: define surface?
Again, the problem is Abaqus does not allow to select a face to make a surface. i do not know what is the reason.
