Hypothetical Roll Centre / Anti Roll Question
At the moment, roll centre migration is static (ie linked inherently to geometry of suspension). Now imagine said suspension has flexible geometry at various stages of travel. The roll centres change (only by a small amount in this case, but change all the same). If roll centres were dynamic but said position was known (calculable) could applying a stabilising force equivalent to the difference between two roll centre instants (opposing wheels) correct for the imbalance in the roll centre location ie uneven moments?
I am trying to get an idea of what is achievable without giving the whole concept away ... Sorry please let me know if you need more explanation or happy to go Private Message as well ..
Appreciate your help ... !
burgie82@gmail.com
burgie82@gmail.com
RE: Hypothetical Roll Centre / Anti Roll Question
Cheers
Greg Locock
You have helped me a lot passively over the past year through reading your considered responses. So, thank you. Hopefully now, it is possible.
More modelling now ;( but :)
