Name for this part/mechanism?
6
I am referring to the gear-like circular faces that interlock when forced together and allow rotation when unlocked on these arms. I want to design one, but I can't seem to find out what its called.
Any advice as to how to make these out of metal in a basic machine shop is also welcome.
Thanks!
RE: Name for this part/mechanism?
Hirth coupling?
We make Hirth couplings all the time in our prototype shop. A rotary indexer and the desired angle of vee cutter is all that's required. (and a milling machine, of course)
Thank you, you guys are awesome.
In the future, are there any tips or resources for how I might go about figuring that out without asking the forum?
Cheers.
I assumed I didn't know what it was and simply used google for "toothed rotational joint" and was able to find reference to a hirth joint in the first page that came up. But didn't find it so easily with Bing.. take that microsoft.. Google > Bing now matter what your commercials say :)
They can put bing where the sun don't shine.
That's where it came from.
Thanks for identifying the Hirth joint - my little bit of learning for today. smile
depending on the accuracy and increment a simpler jaw or dog coupling might suffice
