How to insert a separate drawing as a new sheet for other drawing?
Is there a way to insert a diffrent drawing into another as a new sheet?
RE: How to insert a separate drawing as a new sheet for other drawing?
Using the Merge command in the ADV DWG OPTS menu, you can merge two drawings. Merging allows increased performance and management of large drawings. Individual Pro/ENGINEER users can work in parallel and then merge their separate drawings into a single drawing file. A source file is appended to the target file as additional sheets; for example, when you merge a two-sheet source drawing into a four-sheet drawing, the target drawing then contains six sheets. You can later use SHEETS > Reorder to rearrange sheet order.
I hope this helps...
Thanks a lot!
Being self taught has it's dissadvantages. I never learn anything until I need to, thanks for that tip...it is pretty easy.
