Minimum Nozzle Projection Requirement Per ASME VIII Div.1 ?
As I remembered there are some Minimum Nozzle Projection Requirement for Tanks Per API 650.
But I don't find any Minimum Nozzle Projection Requirement in ASME VIII Div.1.
Can anyone tell me a little bit more about that? Thanks.
MSc. Mechanical Engineering;
5 years EPC experience;
Oil & Gas industry in Canada.
RE: Minimum Nozzle Projection Requirement Per ASME VIII Div.1 ?
If using stud bolts, you need to be able to remove the stud bolt from behind the flange, hence the minimum height will include the length of the stud plus a small margin. In addition, you need to include the thickness of insulation, if applicable. Also, some nozzles need to protrude through the platform grating, hence additional height.
Cheers,
gr2vessels
Mike
