heat exchanger exergy analysis
i am having a problem with heat exchanger (tube and fin) exergy analysis...
the problem which i am having looks like this:
in one of the cases air (mass flow of air: m,a=0,71 kg/s) is entering the heat exchanger with temperature T,aIN=21C and relative humidity RH,aIN=57%, air is cooled to the state where it has temperature T,aOUT=19C and RH,aOUT=64%. Water entering the heat exchanger has T,wIN=7C and on the outlet T,wOUT=14,91C, mass flow of water is 0,043 kg/s.
for exergy calculation:
air inlet entalpy and entropy h,aIN=43,55 kJ/kg and s,aIN=0,1552 kJ/kgK. Air inlet conditions are the same as dead end state conditions. Air outlet enthalpy and entropy are h,aOUT=41,50 kJ/kg and s,aOUT=0,1487 kJ/kgK.
water enthalpy and entropy: h,wIN=29,52 kJ/kg; s,wIN=0,1064 kJ/kgK; h,wOUT=62,68 kJ/kgK;s,wOUT=0,2231 kJ/kgK. Water enthalpy and entropy at dead end state (21C): h,w0=88,18 kJ/kg and s,w0=0,3107 kJ/kgK.
calculated exergies, air: ex,aIN=0 kj/kg;(ex,aIN*m,a): Ex,aIN=0 kW, ex,aOUT=0,1330 kJ/kg, Ex,aOUT=0,0944 kW
calculated exergies, water: ex,wIN=1,4348 kJ/kg, Ex,wIN=0,0627, ex,wOUT=0,2675 kJ/kg, Ex,wOUT=0,0117 kW
if i calculate second law efficiency ( outlet exergies/inlet exergies), i get efficiency: 1,69 !?
i do not know where could be a mistake... enthalpy and entropy values seems to be correct... any ideas?
Thanks a lot!
Thanks a lot!
RE: heat exchanger exergy analysis
Are these values that you have measured?
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
DRWeig, they are not measured. I calculated them, I compared my results with some heat exchanger calculation software, and they are quite similar...
Anyway, wouldn't it be easier to just calculate the loss from the system sum(enthalpy outlet)/sum(enthalpy inlet) which would be the system power loss %, you didn't specify whether the exit values were desired or not.
