friction factor rotating disc plate
Hay,
I have following problem.
One disc plate is rotating above the second stationary one (like rotor stator with a narrow gap between them). A fluid is flowing through center of rotating flow (similar like impinging jet flow fluid rotation disc).
Does anybody has some knowlidge about a fluid friction which flows between rotating and stationar disc plate? If yes what is the equation. Can we use Darcy weisbach equation or is there available some modification?
Any hint or answer is welcome!
Have a nice day!
R.
Have a nice day!
R.
RE: friction factor rotating disc plate
http://www.eng-tips.com/threadminder.cfm?pid=1529
Use translation assistance for Engineers forum
Note the rules include No Student posting
Good luck,
Latexman
here's a starting point:
http://journals.cambridge.org/action/displayAbstra...
