call out of the Assembly sequence
Hi, guys.
I'm having an assembly which consists of sub-assemblies, each sub-assembly has its own sequence so how can I call out those sequences in the main assembly sequence.
RE: call out of the Assembly sequence
You can't. A sequence 'lives' in the current displayed part only. You can manipulate components in a sub-assembly, but all the motions must be defined at the 'top level', as it were. Now if you DO have sequences defined in a sub-assembly, they will NOT interfere with the creation of a sequence in the next higher level, just that it will NOT be accessible nor will it be 'playable' at that next higher level.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
thank you Mr. john for your reply :)
