Installation requirement of Reverse osmosis plant
I am working on a refinery project. There we will have a huge RO plant....
As per my experience I have never seen RO plant in open to sky area. Can anyone tell me why RO plant need a shadede roof? Why it can not be installed in open to sky area like normal waste water plant....?
If instruments and pvc pipes are the only concern to put RO plant in shaded building then why cant we go for higher IP rating of instruments and pipes...with UV protection...?
RE: Installation requirement of Reverse osmosis plant
TTFN
As mentioned above PVC us particularly susceptible to UV degradation. You can change the low pressure piping to something else, but the housing end caps are generally PVC.
Most RO housing suppliers coat the exterior with two-part polyurethane enamel for a high gloss and UV protection.
Most of the components are not uv resistant. You will have corrosion and filth on the equipment. The electrical components are not waterproof. Clean conditions are required when you are loading membranes. You will need a maintenance and storage area anyway.
It is not only sun UV and temperature rise due to solar heating. It is weather - rain, dust, salt mist, sand, sun rays, cold at night, even frost and snow (although rare). You want to protect your equipment in the water treatment plant in RO systems. Electrical panels, Motor control centers, all these definitely need to be housed indoor, some even need air conditioning. Motors indoor are cheaper and you can prevent corrosion on motor and many other metal surfaces.
Another consideration is operation and maintenance. It is much easier to work in door, at day or night. Even for water treatment plants, people still prefer to work on dry floors.
Not all equipment are installed under shelter. Water and chemical tanks can be outdoor.
RO plant buildings has not only shelter, but also other structures inside, like lifting beams and gantries are also under the same building.
