Freestyle - Control point curve on a plane
I'm using the freestyle workbench and I cant find a way to constrain a control point curve to a plane. It seems there is/used to be a "curve on plane" tool that I cant find that might have done what I want. I can set the compass so the control points can only be moved in a certain plane, but it doesn't lock them from being moved in another direction if the compass isn't set correctly. Am I missing something? This is a simple task in UG.
Thanks.
Thanks.
RE: Freestyle - Control point curve on a plane
CATIA V5 R20
PC-DMIS 2011 MR1
