PDF quality in shaded mode
it's possible to increase the quality of the PDF, regarding the capacitor contour ?
Thank you...
Using NX 8 and TC9.1
RE: PDF quality in shaded mode
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
NX8 doesn't support 'Lightweight' in drafting. Components are converted automatically in 'Exact' representation.
Changing the Shade Tolerance doesn't change the result.
The result can be changed in the PDF setting, but what I posted is the 'high' setting.
Open an IR ?
The same drafting in SolidWorks or in Solid Edge produce a good result or a result like 'expected', said like someone would say.
Thank you...
I too had similar issue, but now am using this journal and am satisfied with the quality of pdf output.
http://nxjournaling.com/?q=content/exporting-drawi...
Sundeep
Thank you...
