antisurge system requirement
thread124-130176: Anti surge line of Compressor
Reference to this thread above.
Why antisurge valve is not present in (some) recycle reformer gas centrifugal compressor ?
Thanks for any insight
RE: antisurge system requirement
Can you please elaborate a bit on that.
1/ If there requirement of by pass line is not possible, then how the compressor is protected in case of surge?
2/ Why the reformer as so specific then ? They are subject to same risk to have unexpected process upset, temporary variations of process parameters (flow, inlet/outlet pressure), etc. or not ?
3/ From where comes the impossibility to have a by pass line with a control valve ? it is just an addition piece of pipe with control valve that could safeguard the machine in case something unexpected occurs?
Thanks again for your response
Surge is caused by low inlet volume (left of surge line). The anti-surge valve creates more inlet volume by recycle. The process and the controls can be such that recycle is not needed to stay out of surge, and so the anti-surge valve might be omitted.
I don't really know the application or i would have commented earlier- i.e. what is the control objective, what flow or pressure? Centrifugal compressors can generally be manipulated in the following ways: speed, vanes, inlet valve, outlet valve, or recycle (same as anti-surge which you obviously don't have). Some ways (like suction throttling) are better for staying out of surge than others.
Best wishes,
Sshep
If the compressor's operating curve exist in the minimum flow and maximum head condition (compressor is not able to overcome the system resistance) - surge point.
It to be installed the Spill-back from discharge to suction line, and its to be required for flow or pressure control in the discharge piping. In my limited experience, I never saw any compressor without
spill back line.
Thank you.
I've never seen too but other mention in rare cases (reformers).
That's why I ask for people feedback on such rare cases, eventually to know more.
