error msg while using move feature command
I am using nx8.5. I am working on project for a month. Recently for the last few days I am getting an error msg whenever I try to use move feature command and I am unable to use move features. the error msg reads like "An embedded measure can only be referenced once. Create another embedded measure or use another"
What does this mean? I am not sure even if this msg makes any sense as I am not trying to reference any measurement here.
Any urgent help would be appreciated.
Thank you.
RE: error msg while using move feature command
Do you have ANY 'Measurement' features in your model? Are you 'Moving' or 'Copying' a Body?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
want to move a feature up by 2mm. not trying to copy.
measurement features-I am not sure when you say this.
yes. I have used some simple measurements and then used that as an expression for something else.
I've tried a couple of scenarios which I thought would trigger an error like this but I couldn't. I think you'll have to contact GTAC and have them look at your model.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
thank you
