Two stroke oil in diesel
Having looked here a few weeks ago I thought why not its used in two stroke engines and its obviously a dam good lubericant. Four stroke engines seem to manage it (filling up the law mower forgetting that it is a two stroke mix). At 200:1 which seemed to be the "right" mix I thought here goes and "wow" the 130 defender has more power and sounds quieter. Three days in and all I've got to say is that it's like I'm in fourth gear all the time with the power and responce. I hope I'm not doing any harm but I can't see how as I'm just lubeing the entire diesel system which can't be bad right ???
RE: Two stroke oil in diesel
My guess: It's probably no worse than any aftermarket Diesel additive, but it may take more than a few days for any damage to show up with that mix ratio. ... if there will be any damage. Hey, it's your engine, right?
Mike Halloran
Pembroke Pines, FL, USA
I would strongly advise against it if your engine is 2007 or newer (i.e. if it has a DPF).
