The tips of my 20 mill cutter get loose ...
Hello
Thank you for entering in my post
I have a 20 mill cutter with 3 tips and radial screws, and one of these tip gets loose when it's machining
I remember, when I had my apprentship, we used to use a sort of copper paste on the thread of the screw
I know that this 20 mill cutter with 3 tips is not the best, however I was wandering if this copper past would help to keep the tips, or if there is something-else that would help
If yes, how does it work?
Any information according this matter will be very appreciative
Thank you in advance for your help
RE: The tips of my 20 mill cutter get loose ...
The copper paste is likely an anti-sieze paste. A more logical reason for an insert becoming loose is a damaged screw or a damaged thread in the cutter body. I would replace the screw as a first option, always making sure that the insert pockets are exceptionally clean before tightening the screws.
Thank you very much indeed Ornerynorsk
