Lobe pumps or gear ??
We r using GEAR pumps for viscous+foaming material... e.g- cocobetaine or surface active agents.
Which pump best in performance for above mentioned criteria??
And Y ?
we r facing leakage problem with gear pump .
RE: Lobe pumps or gear ??
I understand you have some pumping problems and you are not sure why are you using the GEAR pumps!, but I fail understand your acronyms and erratic letters in your engineering grammar. Can please translate in English your post?
gr2vessels,
quote
unquote
Did you miss something ?
MilanMhatre,
Kindly reformulate and explain clearly your question.
If we cannot answer, at least we can understand what the point is.
Talk to your CAPB supplier about your application and see what pumps they use. Request their technical support engineer or an engineer in their plant. Don't let the sales people give you their blah-blah-blah-blah.
Where is gear pump leakage? Describe. Packing? Seal?
How much flow do you need? Pressure drop?
What is the viscosity?
Good luck,
Latexman
We 'r' using...?? And 'Y'..?? I fail to understand this 'engineering' language. I know, my English is limited and all I could do was to research in my technical dictionary for 'r' and 'Y', but all I got was a reference to street slang. Is it really some kind of street slang you are using on the engineering forum?
Best regards,
gr2vessels
Looks like SMS language/ English hybrid.
The worst of Y-Gen language perhaps from the disjoint functionality of a mobile device.
r-are
U- You
Y- why
Full translation:
We are using gear pumps for pumping a viscous foaming material such as cocobetaine or surface active agents.
http://en.wikipedia.org/wiki/Cocamidopropyl_betain...
Which pump (type) is performs best for this service??
And why is it best?
We are facing leakage problems with the gear pump that we are using .
http://www.eng-tips.com/threadminder.cfm?pid=1529
Use translation assistance for Engineers forum
Note the rules include No Student posting
i apologies for that,
we are dealing with 4000cps to 15000cps viscous fluid( surface active agent), using GEAR pumps.
but facing problem at rubber seal leakage.
IS LOBE pumps better for above mentioned fluids??
Since you do NOT have gear wear problem, I think a lobe pump is not better. Sounds like you need to improve the seal. Is there a better choice of the rubber? Can you change to packing? Mechanical seal?
Good luck,
Latexman
It all depends... I can give you hand even being a non native english speaker...
Please provide:
fluid temperature
required massflow
required discharge pressure
and VERY IMPORTANT
Available NPSH (net positive suction head) of your system.
Mvelez
