HWT-500 Network Protector Test Set
Does anyone have a wiring diagram that shows how the On-Off switch is connected in the Cutler-Hammer HWT-500 Network Protector test set. When we connect the 3 supply leads the other test leads are energized even with the switch in the "Off" position; this is very dangerous.
