Changing sheet size in NX6
Greetings all!
Let's imagine that in NX6 we need to change the size of the sheet after drawing has been worked on extensively. In other words, views and annotatins already exist, and we need to make sheet larger, which means need to put a larger drawing frame on it. I can think of deleting old drawing fame, editing the size of the sheet, and importing a new frame corresponding to the new size. Obviously cumbersome! Is there any better way?
RE: Changing sheet size in NX6
If you used the first option, my procedure was like this:
1. Insert another sheet in the drawing
2. copy/paste everything from the first sheet to this new one
3. delete the first sheet
With other options, you just have to delete the old frame and import new one.
Hope this helps.
Regards.
2. Second Option: Make all layers selectable → Select all drawing elements (Border Text, curves) → Edit → Transform → Scale. Edit the size of sheet accordelly
MZ7DYJ
3. Delete the first sheet
Thank you! I'll have to test it a little more, but it seems to be working!
Edit->Sheet
Change the sheet size to standard or add custom size.
Mirage
