UPS Output CB sizing
Hello everybody
First of all please excuse my english.
We are installing a MGE Galaxy 5000 UPS rated 100KVA.
In the installation manual they recommand & 250A breaker in the input which i think is normal. But in the output they recommand a 120 A breaker. Is this breaker undersized ? or i'm the one who's missing something ?
I'm always working with the formule : Amps = KVAs x 1.55 so the output current would be normally 155 A.
Thank you in advance.
Amar OUZOU
Amar OUZOU
RE: UPS Output CB sizing
Bill
"Why not the best?"
Jimmy Carter
No idea where you got that formula but it would only apply for a certain voltage and also for certain applications.
The unit has an input/output voltage of 3 phase 380V.
@LionelHutz: The formula has a little error in it; it's AMPs = KVAs x 1.52 and it applies only for 3phase 380V.
S = sqrt(3)*U*I so I = S/(sqrt(3)*U)) this is where I calculated the formula and it' easy to keep in mind.
Thank you to all again.
Did you ask them why they recommended that size? Possibly, they gave that size based on a higher voltage, such as 480V or 600V.
