apply force on a surface, part of a bigger surface
Hi all,
I use CATIA V5 Generative Structure Analysis module.
I need to know how to apply a force on part of a bigger surface.
For example if I have a cube, I need to apply a force on a quarter of one of six faces.
How to set this? When I select a face it aplies force on all the surface.
Thank you very much.
If this is the better position of my thread, suggest me where to post it. Thanks
RE: apply force on a surface, part of a bigger surface
then use the Part Design Sew Surface function. Uncheck the 'Simplify geometry' option
I try as you explained.
But in this manner I can apply forces only out of this surface extracted. I need to apply forces in.
Where is my error?
I don't undestand the difference!
You selected Part Body in the tree.
It's correct to say that in my previuos manner I apply force only out my surface?
You can not apply the force to the surface, only to the solid face.
i hope the image works
Ok, but if I do not select Part Body, it seems that I apply force only on solid face without surface created in the solid face. It is correct? Or in this manner I apply the force to all solid face?
