Natural Gas Condensate
Hello together,
a gas turbine is operating with natural gas. The dew point of the gas is 35°C. The supply pressure 30 bar and the mass flow 7 kg/s. In case the natural gas temperature is below the dew Point, e.g. 30°C condensate should occur.
Is it possible to calculate the amount of condensate within 1 Operation hour.
Thanks for your help!
RE: Natural Gas Condensate
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
The plural of anecdote is not "data"
See page 8
http://www.sintef.no/project/Trondheim_GTS/Present...
Independent events are seldomly independent.
The term "Natural Gas" is very context dependent. Commodity "Natural Gas" has no condensible hydrocarbons while wellhead "Natural Gas" can have significant natural gas. With 0.34% C7+, this ain't commodity gas.
It is possible, but incredibly complex to predict the liquid fall out. You need to use something like Hysys, or ProSim with a detailed analysis (typified C7+ won't generally work, you need an extended analysis). For less than $20k worth of software your options are very limited. You just can't successfully do the MANY iterations required by hand.
David Simpson, PE
Can you calcualte it - yes, but as zdas04 says very eloquently, you need a decent computer simualtion package (HYSYS etc) to work it out.
I would stick in a pre-heater if I was you - I've had to do that on many fuel gas systems to get the gas above the water and condensate dewpooint. If there's one easy way to wreck a rather expensive GT it's putting liquids in it that it doesn't expect....
David Simpson, PE
I have always assumed CH4 + water in the absence of a stream analysis.
Anyway, and fortunately, you asked him directly.
