Location PSV upstream or downtream a check valve blocked in closed position ?
Good morning
I am designing a lube oil system for a turbo expander
This turbo expander is supplied with two oil pumps (1 for normal operation + 1 for back up)
A check valve is placed dicharge line of each pump
and I am asking if two PSV placed upstream of eash check valve are required to avoid overpressure, or if one PSV placed downtream (T connection)of the (*2) check valves is sufficient.
In other words, shall we considered check valve could be blocked in closed position or not.(API requirement ?)
Are there any standard dealing this problem ?
Thanks in advance for you reply
Best regards
Matchess
Best regards
Matchess
RE: Location PSV upstream or downtream a check valve blocked in closed position ?
