equivalent load diagram in etabs
hi,
I'm analysing a multistory concrete building in etabs. I use auto mesh option and auto line constrain. When i investigate force diagram for vertical load of a beam i found one of the equivalent load is upward (marked portion in attached file).But when i remove auto line constrain all equivalent load is downward. What is the logic behind this?
RE: equivalent load diagram in etabs
BA
As my understanding auto line constraint is nothing but a tool that reduce hassle of fine meshing.
@BAretired i m not practicing what i do not understand. I m just want to use auto line constrain without fine meshing manually and want to verify this command that's why i raise this question in this forum.
Michael.
"Science adjusts its views based on what's observed. Faith is the denial of observation so that belief can be preserved." ~ Tim Minchin
