ISO 2553 Weld Symbol letters
Can anyone tell me if the letter "s" is required before the dimension for weld penetration on anything other than fillet welds? I can see from the standard that an "a" or a "z" is required when specifying fillet weld size but the examples for other welds are unclear as to the requirement for the "s".
Pete
Pete
RE: ISO 2553 Weld Symbol letters
you are read in section 6.2.3 is explain
The standard is fairly clear on what the letters stand for, what is not so clear is whether or not the letter s has to precede the penetration dimension when one is used (no dimension implies full penetration.
