Creating a Pipe in an assembly
I'm trying to create a pipe/tube to connect two arbitrary shapes in an assembly which aren't in the same plane. Is there an easy way of doing this with a 3d sketch/sweep (or any other method) without having to dimension the entire drawing? Is the piping add-in a possibility? If so, how do I use it?
RE: Creating a Pipe in an assembly
The piping program, as far as I am concerned, is not worth the money. If it was free then it would be worth a look. But for what you are trying to do the 3D sketcher will work.
BBJT CSWP
I would like to be able to snap from one face to another face in my 3d sketch. The help file says you can do this as long as you aren't sketching in a major coordinate direction, but I haven't been able to snap to anything yet...whether or not I'm in a major coordinate direction.
What's the deal?
Scott Baugh, CSWP
credence69@REMOVEhotmail.com
http://www.3dmca.com
http://home.insightbb.com/~scott.baugh/
*When in doubt always check the help*
