Loop Sheets
Loop Sheets
Loop Sheets
What is a loop sheet?
Well how about this, A schematic or diagram that shows a particular Master control components or equipment that is laid out start to finish or looped. This single system layout will show which component or equipment with start first in sequence and continues down the line. This loop sheet is also used as a fundamental guided for a Preventive maintenance schedule, like a boiler.
Question:
Is the Loop Sheet a followed PLC programed Block-ware
or
Is it a walk-through report that is turned into a PM?
I am coming form the PM side of this , that is trying to create PM's for a Big boiler system.
The more explanation the better.
Thank you
