Rotate a raster image
I have to turn precisely a raster image, but there is no way to enter a value like when rotating the WCS. Am I missing something ?
Is there a way to decrease the sensibility of the mouse in this case ?
Another problem is the snapping to the original position.
Thanks in advance
Thanks in advance
Didier Psaltopoulos
http://www.psi-cad.com
RE: Rotate a raster image
www.nxjournaling.com
This way you don't have to change the mouse sensitivity.
AH
AH
It' not correct. We are not limited to 90°, but the main problem is the "snapping" to the original position. Did you try it ?
Didier Psaltopoulos
If you truly need to have a 'rotated' image on your drawing at something other than at 90° increments, you will need to take your original image into some sort of image editing program, like Photoshop (note that even 'MS Paint' will only rotate an image using 90° increments), and rotate it there to what you desire and then place THAT image on your Drawing.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Note for NX 9.0 the 'Raster Image' function in Modeling has been completely reimplemented and you will now be allowed to use the CSYS drag handles the way you would with any other function, where you can either dynamically drag the image or enter explicit values for X and Y or Angle. We've also removed the restriction of only supporting TIFF images. A 'Raster Image' can now be any of the common image formats, including JPEG, PNG as well as TIFF.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I apologize because I forgotten to say that I was talking about 3D Raster Image and I am using NX8.5.2
I don't agree with your suggestion about Move Object because It will distort the image! as said hovelale or only the sheet body is turned (have a look at the attached jpeg file)
Didier Psaltopoulos
Of course, this will all be moot when you update to NX 9.0 as you'll have no problem using the new 'Raster Image' function to position the image exactly as you wish to.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
It's exactly the method I found but in my case I was not able to rotate 1 or 2 degrees
As I am a beta tester, I tried the new method to add raster image in NX9. The enhancement is correct but I found a bug already reported 2 days ago in phase 15 by me.
When opening a part with new raster image, an error occured, the image doesn't appear and the part can't be saved: did you encountered this problem ?
Didier Psaltopoulos
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I was able to reproduce the pb and I found a WA
New Part
Add raster image
Save and close the part
Open the part => OK
Add a sketch
Open the part => the problem occured
Let me know if it's OK in phase 16
So, the WA wiil be to create a sketch first !!!
Didier Psaltopoulos
Didier Psaltopoulos
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
It's not the same part.
Did you try to reproduce the same steps with an new file and another image ?
Didier Psaltopoulos
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
