Nx Thermal/flow advanced simulation
hey all
make an assembly when done do advanced sim. then after 3D meshing setting the boundaries 2d joints and heat loads it shows the next error when running the solution
WARNING
There is a model update pending.
Perform a model update or the results will not reflect
the changes made to the part.
thanks
WARNING
thanks
