Script to set front view of a surface
How to set a front or side view of selected part using vba in catia
what code or command has to be used
Any suggestions will be helpful
Barath
Barath
RE: Script to set front view of a surface
CODE --> CATScript
Sub CATMain() Dim ActDoc As Document Set ActDoc = CATIA.ActiveDocument Dim camIsoView As Camera3D Set camIsoView = ActDoc.Cameras.Item("* iso") Dim objIsoViewPoint As Viewpoint3D Set objIsoViewPoint = camIsoView.Viewpoint3D Dim ActWin As Window Set ActWin = CATIA.ActiveWindow Dim ActViewer As Viewer3D Set ActViewer = ActWin.ActiveViewer ActViewer.Viewpoint3D = objIsoViewPoint End SubRegards
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
Hope this helps.
Regards.
