Protecting food grade systems from contamination
Hi Folks,
I have a design where I'm taking liquid CO2 from a food grade tank (used for export) and installing a new tie in to a 45MPa definitely-non-food grade reactor via a high pressure cryogenic piston pump at around 36kg/min.
I'm concerned about potential reverse flows contaminating the tank. I have little confidence in standard non-return valves in this pulsating high pressure service.
Can anyone point me to a good technique for ensuring no reverse flow in a very high pressure cold (-24C) line?
Thanks for any comments in advance.
John
John
RE: Protecting food grade systems from contamination
