editing the Instance feature - highlights different one - NX8.5.1.3
When I edit the instanced feature (hole dimension),it highlights the source object always.It creates conflicts like which object we are editing.
Mathi K
RE: editing the Instance feature - highlights different one - NX8.5.1.3
When you select the Instance it will highlight THE instance and NOT the 'template' (AKA the "source object"), however, it is true that when you go to edit the parameters of that instance, it will highlight the 'template', but that should not be causing you any problems since the update will only apply to the actual instance being edited.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
