Configuring dimensions in clone/child files
Is there a way around to configure a certain parameter without calling it from the part family table.
For e.g. if I created 4 part files(child parts) from 1 master model and I have 5 parameters being controlled from the part family table. Is there a way to control a 6th parameter without calling it in the part family spreadsheet.
Currently we are working on Solid Works (in which we can use either design table or just rigth click the sketch --> configure feature --> change the parameter of two configurations) and are moving to NX8.5, so looking into how we can make the procedure similar
This prodedure is specially required since we do not preapre a model from scratch for different line sizes keeping the part family structure standard through out our product range.
Thanx!!
Thanx!!
RE: Configuring dimensions in clone/child files
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Consider that I have created a datum plane at "X" distance from the origin in the master model. Now I want the distance to "X" for 2 part files and ".5X" to the remaining two part files. How can I do achieve this without calling this "X" dimension in the part families table of the master model or saving as the two child files?
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Please find the model. When we edit the sketch 2, the line 1 should be collinear with the edge marked in red(attached snap) and line 2 should be collinear with the edge marked in green.
Also if you enter the drafting enviornment of this particular model, I drew a arc and made it concentric with the circular edge of the cylinder. Now how to make these two curves coincident.
Thanx
Gokulkrishna Goli
NX8.5
