Solar PV Array Grounding
I am working on completing a ground potential rise and grounding study for a large 10 MW ground mounted PV installation. The site will be interconnected to the utility grid via a 44/12.5kV substation with the substation ground interconnected with the PV module grounding system. The 44kV system has no neutral or ground return. Prior to completing the modeling I wanted to determine whether it is common practice to install a buried ground grid conductor around each array support structure in order to address possible touch potentials transferred during substation HV ground faults? Our modeling will help us determine the potential hazards based on the soil resistivity but I just wanted to inquire about the common industry practices.
RE: Solar PV Array Grounding
