Any way to unstack stacked fractions ?
I'm looking for that variable now ! One of our guys stacked fractions in a dialog asking about preference, and thinks he probably clicked the wrong box. Now the ability to stack/unstack is greyed out. I'm sure there's a controlling variable for that.
Also, tr1tx posted a question in my earlier Q;. He's interested in how to return his fraction to mid-justified with the base text. Now it seems to be bottom justified after an edit.
Thoughts ?
Thanks -
C.
RE: Any way to unstack stacked fractions ?
You can return the text to its default position with DIMEdit Home and pick the dimension(s)
If DimLUnit is set to 4 or 5 then DIMFrac changes from stacked to not stacked
When editing the text, if you highlight *just* the stacked portion, you should be able to right click on it and have the "Unstack" option. It may be different in earlier versions of CAD, I'm on 2013.
