Start stop using one push button
I am trying to use the one push button to start and stop. I am using difu for the rising edge and a standard latch but my trouble is how to get it stop the second time the button is pressed. Has anyone any experience in this?
RE: Start stop using one push button
This is just for exercise purposes. I am having trouble writing the logic to get it to stop.
AND the state of the latch with your rising edge to determine wich direction to take the latch. SETLATCH=NOT LATCH AND REDGE. RESETLATCH=LATCH AND REDGE. Don't know what a difu is, but it sounds bad.
"Don't know what a difu is, but it sounds bad."
I believe this is the instructors term for "plagiarism". :)
Forget what IRstuff says about bad practice, its actually quite common practice and nothing wrong with it, it has its uses.
The easiest 2 line code is as follows.
Pushbutton Trigger
---[P]-----------( )---
Trigger coil coil
Trigger coil |
The rising edge of the pushbutton turns on Trigger, then Trigger will make the circuit on branch one if coil is off, or break the circuit on branch 2 if coil is on, as its a one shot, the next scan coil will remain at the changed state.
Then coil can be used to energise a lamp or other indication so you know the status.
Hey guys,
I prefer to use a counter, but to each his own.
