Topology optimization on a STL imported body ??
Hello
The result of my topology optimization is a STL file.
I want to use that file to perform (see) again stress analysis but NX doesn't allow me to select that imported body.
How can I do it?
RE: Topology optimization on a STL imported body ??
You will need to first convert this .stl file into a some sort of solid or surfaced model. There are 3rd party reverse engineering applications (and even some service bureaus) which can help with this step.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thank you johnRBaker
can't you just open (import) the stl and save it as .prt. that might allow you to use it in an analysis.
apart from that NX might have an option to convert a stl to a surface/ solid model, like catia has.
