Question - Pressure relief valve
I work in a gas analysis lab.
3000 psi gas cylinder > pressure regulator (Cv 0.05 to 0.1) to 70 psi depending on gas > manual valve > 1/8" (3 mm) OD metal tubing, 1 m long > my gas analysis instrument.
Per company safety code, I have to install a pressure relief valve in case of pressure regulator failure.
I checked Circle Seal catalog. 1/4" thread, deflector cap, 80 psi crack open, 36 scfm @88 psi, 50 scfm @100 psi. Is this flow sufficient?
Thanks.
Thanks.
RE: Question - Pressure relief valve
Just search flow calculation choked flow or valve flow and this will give you proper value. Don't skimp on this and add a bit for error. Pressure in this system will build in seconds if the regulator fails open and you need a bit of spare.
Something with a wide open Cv of around 0.05/0.06 is usually more than sufficient for a lab analysis type situation (I assume this is a carrier/cal gas application?) and will help reduce the size of relief valve substatially.
We use some instrument regulators that due to their wide open Cv rating (0.138) will usually require a relief valve somewhere around 1" inlet connection when used on natural gas applications (size dependant on process conditions of course).
Yes, the gases are for cal, carrier, fuel for flame ionization detector. Cv 0.02 can give sufficient flow.
