Measuring Gauge for Intake /Exhaust valve
Is it possible to explore online for more varities /standards of gauges that are suitable for measuring intake/exhaust valve for engine. Is there any companies delivering high quality measring devices for such purposes?
I just need to select a good measuring gauge for intake valve measurement
RE: Measuring Gauge for Intake /Exhaust valve
Please give us a clue about what exactly you wish to measure.
Mike Halloran
Pembroke Pines, FL, USA
Gaging can be as simple as mcgyvr has said or highly automated. Your valve stem is probably your closest tolerance dimension. A simple go / nogo snap gage will tell you if the part is good or bad. Process inspection will require knowing where in the tolerance band you are making the part so an indicating gage will be required. Roundness of the stem and finish are also required. The following is old used piece of equipment.
